Boating Logo
M
Mark Duncan Posted on Oct 11, 2018
What is the year of my Yamaha 50hp 6H5 L 903842 T
Kirke Campbell
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Jan 19, 2019
Kirke Campbell
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
5
Questions
0
Helped
1111
Points
7
2answers
Yamaha 50 outboard bogs at hi speed
Make sure carbs are clean,check exhaust tube isn't blocked,check resistance readings on charge coil,make sure filters are clean,no fuel leaks in fuel line,tank has open breather,fuel connector not blocked.if this doesn't solve the problem could be faulty cdi unit
My Yamaha 4 stroke 50hp engine was running fine. When i went to replace the cover, the water stopped running through the "pee" hole.
i have had this on mine and it was a sort of insect that made a mud nest in the small hole and it blocked the hole up ,try poking it out with a bit of wire
2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
4helpful
3answers
4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
1helpful
I want to sound proof the engine cowing on a 50hp outboard
Marine stores have a lead lined foam sound proofing mat. You can cut and glue it in place.
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
