SOURCE: 1992 Mazda MX-5 Door handle problem.
you will have to take the panel off to see why the inner lock/activator isnt working properly, besides youll have to take it off to fix it anyway.Maybe as simple as a bent handle to lock rod being bent and no longer long enough to activate lock correctly.youll just have to look and see.Let me know what you find
SOURCE: Right Rear door will not open from exterior or interior.
Took off inside door panel and flipped the child proof lock. Mechanism for entrance from outside handle broken. Replacing it.
SOURCE: driver's door won't open
The problem is the door latch, you can use sawsall to cut the door stricker off this way you can open the door and replace the latch
SOURCE: rightside interior door handle not opening door
It could mean the rod connecting the handle to the latch has broken. You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. and you can access the innards of the door
SOURCE: door will not open with handle
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ---- http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html ---------- Car door will not close? -------- All power door locks not working? ---------- Repairing car Door lock Actuator? ---------- http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html --------- http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html ----------- http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html -------- http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html ----------- http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html ---------- http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html ---------- http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html --------- http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html -------- http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html -------- http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html -------- How to replace Door Hatch ? --------- http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html -------`- -------- Remote will not unlock Rear door? -------- ---------- http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html This will help. Thanks.
Drivers side front door will not open from inside or outside?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
Truck Door will not close?
Where is Cars Door control Module located?
Power door locks not working?
Door ajar light stays on?
Door locks not working?
Front Door dis-assembly diagram?
Rear Door dis-assembly diagram?
How to test Power door locks?
Doors will not open with Remote?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working?
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
Fig. Removing door lock actuator
Fig. Removing door lock motor-Sedan
