SOURCE: My 1080i has a triple picture, can you help?
It definitely can be fixed the IC chips (called STKs) that line up the images from each picture tube are failing.Sometimes a fuse or resistor go out along with the chips. The parts would cost around $100 + whatever labor charge if you hire someone.
SOURCE: Display screen wont turn on
Do the oven work at all, if it does not you will need to turn the breaker off and back on, it may need to be reset, it will appear fine but it will indeed need to be reset.
SOURCE: Hi, my name is Johnny
Your TV has a bad panel. Your Panel needs replaced. Would be more cost effective to replace the TV.
SOURCE: Element Electronics 32" FULL HD
What exactly do you mean by goes silent? Does the screen turn off but you can still hear the audio? Please provide this info so that I can help you with your problem.
