SOURCE: self propelled motor mower runs but doesn't drive
problem could be:-
1 broken drive belt or it is slipping ,if so simply tighten drive cable
2 drive pulleys worn allowing belt to slip
3 teeth in drive wheels damagedcheck these out first
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
SOURCE: self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
