Use TV menu and scan for over the air channels - need outside antenna connected to antenna connector on rear of TV to veiw air channels. https://www.6ya.com/callphilipforhelp
BY CONTROL PANEL GO TO NETWORK CONNECTION THEN CLICK ON WIRELESS NETWORK CONNECTION AND ON THE BOTTOM THERE IS A TAB VEIW WIRELESS CONNECTION A BOX WILL POP UP WITH ALL WIRELESS NETWORK CONNECTION AVAILABLE. dO U HAVE WIRELESS CONNECTION OR DO U WANT TO CONNECT TO SOMEONE ELSE? MAKE SURE YOU HAVE THE WEB KEY FROM THAT OTHER PERSONS ROUTER. OR YOU COULD CONNECT TO A WIRELESS NETWORK THAT DOES NOT HAVE A LOCK ON IT.
GOOD LUCK
PLEASE RATE ME 4 THUMS
P.S. MAKE SURE THE WIFI BUTTON IS TURNED ON ON YOUR COMPUTER OR THAT THE LIGHT IS ON.
Make sure that the wireless is turned on, on the laptop. Then go to network settings and veiw wireless networks, or if your running xp double click on the wireless signal on the bottom right corner. Click on your wireless sigal and hit connect and that should be it.
camcorders have component or hdmi or Svideo port check that whitch one is on your TV and cam,them connect them; put yor tv on AV channel and camcorder on Play mode.
I hope this helps...
make sure you have the correct settings such as the type of security wep,wpa,wpa-psk,etc...make sure your security key is correctly entered, If your not sure open up a web browser and put http://gateway.2wire.net in the address bar go to your wireless security part of the modem and check your settings best thing to do is to hardwire to the pc and then go to that link. what kind of operating system do you have ?
If its a wired connection it will automatically know that its connected to it. With the wireless you need to veiw the available networks before you can connect to the network. And if the router is already configured for internet they will automatically get the internet connection.
If you need help to make sure that the router is online. Kindly provide me with this info;
Internet service provider:
brand or model of Modem from internet service provider:
Operating system of the computers:
uhm if you are talking about how to connect to live. You might want to use this simple method. You will need a laptop/desktop, and a wireless network. Ok take ur laptop, go to my network settings, go to veiw network connections. Then press on the wireless conection icon. From there you have to click poperties. Then click on the tab that says advanced. There you should check both the boxes that come up, then click ok. This will make your computer share the network. Now you can hook the laptop to the 360 directly for no cost, (using the ethernet) and you will get wireless connection!
