Its mated with a grandtec PC-2-VID component. No hay nada
Hi, depending on your computer monitor output, you need a video converter from VGA or HDMI to composite (RCA yellow connector) or S-Video , and corresponding cable. also another for audio output from earphones, called "Y" audio cable. The following pictures are examples of VGA to composite video converter and Y audio cable.
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
SOURCE: My monitor has a bad image when connect GrandTec
Issue occurs due to interference and weak shielding.Using higher quality VGA cable will help also you may optimize display properties such as resolution and sync frequency
SOURCE: having trouble connecting my dvd to tv...have
Maybe the issue is with the dvd player, not the tv. Try it on a different tv to make sure it works.
