Hello dear how are you
you should press exactly in sequence what i tell you
press the speed arrow down three times
then press the stop three times
let me know if you solved it
hello dear how are you
you should press exactly in sequence what i tell you now in less than 4 seconds
press speed arrow down three times
then press the stop arrow three times
some machines use other way to immobilize off like this
pause three times
then speed down three times
SOURCE: life fitness 9500 is shocking users? help?
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
SOURCE: How to adjust the tracking
Please read the link below.
http://www.ehow.com/how_5148912_adjust-belt-treadmill.html
SOURCE: Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
SOURCE: how do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
