SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
SOURCE: outside calls are going directly to voicemail
there should be a switch at the side of the phone that controls this.
you need to set the amount of rings u want before it goes to voicemail.
sam !
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
SOURCE: How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
