Question about Dell 2155cdn
Dell 2155CDN Black (K) cartridge will not pull out to replace.. Stuck.. do not want to force it. Any suggestions??
How to print black only, yellow is out?
Most printers will not allow you to print without all cartridges active. If you printer is capable of that you can go into the printer settings on the control panel and go into options or print menu. Under that you can select B/W printing only. Try that out.
Jul 15, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Dell 2155cdn toner rubs off
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
Feb 19, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Stuck cartridge
Best thing I can recommend is to take it in for service. If you would rather risk breaking the printer you could try removing the cartridge forcefully with a pair of pliers. If you have some experience with removing covers on electronics, and you have screwdriver bits to match the screws, you could dismantle the case until you can reach the area where the cartridge is stuck and dislodge it directly, again risking damage, but if you take your time and don't apply too much force you may succeed.
Nov 10, 2013 | Dell 2135cn All-In-One Laser Printer
Dell 2155cdn default password
NOTE: The default user name is "admin", and the default password is left
blank (NULL).
From the Dell 2155cdn user manual, page 363
May 04, 2012 | Office Equipment & Supplies
Printer does not print using black ink
Check your settings i=under the Services Toolbox. Also go into printer preferences and see if you can force it to print in black only.
Apr 26, 2010 | Dell P703w Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
I can't get the color cartridges removed to replace them. They all seem to be stuck and Yes, I have lifted the lever up to unlock the cartridges and the color needed to be changed is in front. It all seems...
Mine is pretty stubborn about letting go of the cartridges too. The best answer I can say is DON'T FORCE IT!
For mine, after turning the lever to unlock, I push the whole cartridge to the left slightly, then pull on the right (side with the lever)
If it doesn't let go, try turning the lever to lock it, then unlock it and try again.
I honestly don't know how I get it to release the cartridges, but it's never let one go on my first try, and it's always (eventually) let them go without forcing anything.
Jul 16, 2009 | Dell 3010cn Laser Printer
How do i replace cartridge
There should be a diagram under the cover that shows how to change cartridges. Usually you just lift cover and wait for print head and cartridges to reset to middle position. Grab cartridge and pull up and towards back of printer until it is free. Make sure you remove tape from new cartridge and insert and push until seated ( usually go back in at an angle first ) dont force it but dont be too gentle either, they do need a little force sometimes.
May 22, 2008 | Dell 924 All-in-One InkJet Printer
Dell 2155cdn Logo
149 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
