no listing for Sherwood receiver. must do the remote "search" function. here is how:
Turn on your TV.
On the remote control, press TV once.
Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
Using the number pad, enter 9-9-1. The TV key will blink twice.
Aim the remote control at the TV and slowly alternate between
pressing Power and TV. Stop when the TV turns off after pressing the
POWER key. This means that a working code has been found.
Press the SETUP key once to lock in the code. The TV key will blink twice.
Turn on your TV.
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
