SOURCE: Installing printing applications on Lexmark x7170
Here u go:
http://www.downloaddelivery.com/en/cpddrivers/133.html
or:
http://www.opendrivers.com/company/2287/lexmark-free-driver-download.html
and please if u got help rate this solution as SOLVED
SOURCE: Where to find X7170 install program
Here is a link to download your driver. Please pick the correct operating system and run the file after you download it. This will install your printer driver. This should fix your problem. Let me know if I can help.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X7170
SOURCE: Lexmark E120 does not print
Check your driver is correct for your XP OS... below link might provide you some information to help resolve your issue
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
SOURCE: Lexmark 2470 only prints 1 page out of 10 pages!!!!
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Testimonial: "Thanks!"
Should you really need the install disc, please try to contact Lexmark Technical Support Center for assistance.
