SOURCE: Burner adjustment
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
SOURCE: groen tilt skillet 750 mv control
you need to check the generator in series with flame present. remove one wire from gas valve.put 1 of your meter probes under gas valve terminal where you removed one lead from powerpyle generator.put generator on other probe anything over 600 mv and your generators is ok under replace
SOURCE: engine lurches-check engine light comes on. loss
First check the Throttle position sensor. Using a multimeter set it to read resistance. The connectors must be disconnected from the TPS. Probe the middle pin and one of the pins, and as you slowly open the throttle by hand the resistance should start changing smoothly. Then keep the probe in the middle pin, and do the same on the other pin. Do this this carefullt because it is easy to get a false reading. Do not buy a new TPS unless you are sure because they are expensive and usually not returnable. Thats why it is important to do the test carefully.
SOURCE: Temp runs only 180 degrees. High temp thermostat
yes thermostats wear out. make sure your cooling fans are not running at the low temp you have. you may have a bad temp sending unit. also you gauge send ing unit could be bad.
SOURCE: 1998 Jimmy with electrical controls
Suggestion: see if the blend door opens or closes completely to allow all air through the heater core. To see the blend door moving, remove the panel that says "Cut here for service" under the hood along the firewall. I have a 99 Bravada where the blend door keeps moving back and forth constantly. Changed the blend door actuator but still keeps moving. The air inside is only warm since the door keeps allowing bypassed air through.
