For all Blaupunkt radio codes contact this link and pay a small fee for them to retrieve the code for you: Car radio codes in Heathrow London Gumtree
The radio will have to be removed from the dashboard.
Post the radio make, model and all the numbers on the label on the metal casing
Radio Codes and advice are always available here
www.ukbookshelf.co.uk
Mention FixYa Forum
There are websites charging various prices for radio codes with highly variable success. Sometimes a boffin with a laptop can decode a radio, for a price, but the official method is to approach the car dealer (if the radio is still the original) or contact Blaupunkt with the radio model and serial number, both of which tend to make quite a high charge for the service.
The radio will have to be removed to access the numbers - with luck someone will have written the code on the radio.
Great care must be exercised to enter the code exactly as per instructions which will be found in the vehicle literature pack.
SOURCE: car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
SOURCE: audi radio code
I accidentally tossed out my 1993 Audi 100CS radio code
when getting rid of junk in the glovebox.
After changing my headgasket on the motor we reconnected the battery supply & found the radio on SAFE mode.
AUZ1Z7N2020175 is the Radio #
Anyones help to me at [email protected] is appreciated.
Thank you in advance!
SOURCE: need security code for car radio
take out the radio by just pulling it toward u and take it to a holden dealer and they will get the code for u for $40
SOURCE: Car audio security code
pin is on the metal frame of radio on left or right side and on sticker starting with the letters BP- then your 4 dig pin also the radio code after the pin write it down to. swich your radio off press hold the AS button while holding AS button down press power button it will automaticaly ask for security code enter security code then radio code
SOURCE: i bought an Audi A3 secondhand with audi chorus
You must retrieve the code that comes with the Audi's radio unit. To change to safe mode:
