Question about Kenmore Microwave Ovens
My refrigerator says its a Sears Kenmore Canada Model 970-705006254
But i guess its really a Frigidaire But when ordering parts for it it says wrong model number. What model number should i be using when I need to order parts? Sears Kenmore or Frigidaire? Putting in model number doesn't work. Thank you
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Posted on Dec 31, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Posted on May 12, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE spacemaker XL1400, Model number JVM1430WA 001
OOPS!
I meant to post that as a solution, not a clarification request, so it came out as one big blob paragraph (Thanks, FiyXa!)
Here it is again, but in readable form:
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It is part number WB27X10171 and while GE sells it for a whopping $115.50, you can get it for $90.58 here.
You can also find helpful exploded view diagrams via that link.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs, in this case
$90.58 plus $8.95 shipping for a total of $139.48.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 25, 2009
Anonymous
SOURCE: Kenmore spacemaster microwave Auto recipe 300
My 300 model number is 564 8898410.
Must be a later model.
I'm looking online for a operating manual.
Posted on Aug 29, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: I have a Kenmore Microwave hood combo model number
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on May 16, 2010
What stores in Ontario Canada carry Galaxy 64002 700 Watts Microwave Oven ?
Hello Passion,
The Galaxy microwave oven that you speak of was manufactured by Sears, Roebuck and Company. This brand of microwaves is no longer manufactured by Sears. Sears has went to a new model the MD series that you can purchase. However, if you are just looking for a few parts like the plate, manual, etc. the following website has parts and the manual http://www.hammerwall.com/Manuals/Galaxy/Description/721.64002/Galaxy%20Microwave%20Oven%20Manual/L0310102/
To locate a sears store close to you enter you postal code at the following web page http://www.sears.ca/store-locator
Thank you for choosing FixYa.com
Justin
Mar 16, 2011 | Kenmore 64002 Microwave Oven
Is it possible to change the light bulb in the microwave?
It depends on the model number. You should check your owner's manual first.
If for some reason you don't have your manual, many are available online.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download GE owner's manuals and installation instructions here.
You can download Frigidaire owner's manuals and installation instructions here.
You can find many Kenmore manuals by entering your full model number at the
Sears Parts Direct Web site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 22, 2011 | Microwave Ovens
Sears / kenmore Is there an operating manual on line
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
You can just enter your full model number at the
Sears parts site.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
May 13, 2010 | Kenmore 63792 Microwave Oven
How to remove microwave from wall
You may be able to download the installation instructions from the Sears parts site.
Just enter your model number there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpg439cb0b.jpg
Many times, the owner's manual will also have the installation instructions inside.
Sears parts site.
For repair service on Kenmore appliances, see Sears Service.
Jan 29, 2010 | Kenmore Microwave Ovens
Kenmore "Elite" Microwave Gliding Tray jumps Off Track
Thanks for your input - be sure to relay these messages to Sears.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2009 | Kenmore 80809 Microwave Oven
Owners manual for Kenmore Elite Microwave Model 66462
You can just enter your full model number at the Sears parts site.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
Sears parts site.
Jan 18, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
Turntable on Kenmore Elite will not turn?
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
If you don't have your owner's manual, you can just enter your full model number at the Sears parts site.
Sears parts site.
That's where you could also order any needed parts and find handy exploded parts views.
Jan 04, 2009 | Kenmore 63792 Microwave Oven
I need vent dimension for Kenmore Microhood combination model #8162. Is the vent at the back 3x10 or 3x12?
Just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
Many times, the owner's manual will have the installation instructions inside. This is where you will find that information.
Sears parts site.
Dec 16, 2008 | Kenmore 63763 Microwave Oven
Replacing the outer frame on a kenmore microwave door.
It's really not too hard.
The first piece of advice would be not to remove the door from the oven or tamper with the hinges. The alignment of the hinges is important to prevent microwave leakage, which can lead to burns and damage.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 08, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
