Get a new TV you cheap dude
I would certainly have a servicer check the Cable/satellite box. I have seen this with Dynex TV. But try this. Power off box, if there is a service card, take out, unplug box for one minute. Plug box in, insert card and power up. If there is no card, do as said...only. Let me know what you find out. Matt of Martins TV Repair.
SOURCE: Volume bar won't go away
went to hp and talked to a support person who gave me this driver update: ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe.. visit their website this is a pretty common probem....
SOURCE: 2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
SOURCE: Dynex t. v. the volume control button increases
Make sure this is happening from two sources such as a dvd player and a gaming system as well. If it happens from two sources the speakers are more than likely not working or the sound board will need to be replaced. A cheap way of getting around a repair is by getting a surround sound and running a cablebox, dvd player, and/or your gaming system directly to the surround sound system using it for sound instead of the tv.
SOURCE: Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
