SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
SOURCE: archos av700 charging problem
Hi
Buy an external charger as the charging circuit has blown.
You can get them from ebay.
Cheers Boyce - Boyski1960
SOURCE: Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
SOURCE: No Sound or lights on the docking bay of the headset...
Hi Scott, have you tried disconnecting the power to the base with no headset, then power back on the base and reset the headset all lights on the base should light up to pair the unit, if the on light doesn't work after doing this process i would replace the battery in the headset, GN Netcom are shipping out new battery FREE for the GN 9120 a recall default. go to there web site for more details. Good luck
SOURCE: GN 9350 Headset won't charge, blue light remains off
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
