Normally it is supposed to have a swipe/insert card here screen but, last Friday it only had a swipe card screen and would only let me swipe cards. This Saturday my coworker told me that the screen actually had the welcome message on it. When she found that, she unplugged the screen and plugged it back in. Ever since then the device would only flash on and off when we plugged it in. We have been keeping the device unplugged ever since. Let me know what we could do.
SOURCE: SD Card Reader won't work?
have you tried other sd cards before or is this the first time?
if you have and its just this time it hasent make sure its working in your camera or mp3 player or where ever it came from :-)
if it works have a look in your device manager to make sure there are no problems with the drivers.
1 start
2 control pannel
3 system
4 then the hardware tab and click the device manager.
if there are anyproblems there is useually a little symbol next to the device just double click on it and have a look for the error code.
if all else fails try reinstaling the driver for your card reader or find an updated drivr download.
hope this helps
SOURCE: flashing screen
you might want to check but i think that the w810i can only hold a 2 micro card. thats probaly why its not working. the pantech duo is oen of the ponly phones that can hold the 4.
SOURCE: sd card reader not recognized when card inserted.
The solution is to go to your device in device manager on the driver tab simply disable then re enable the device - problem solved in seconds - no need to re install your OS system.....
SOURCE: insert smart card into reader
u have not properly removed it when it is used.u insert u r card and press continue and properly remove it
SOURCE: hello, my hp compaq nc6220 gives insert smart card into reader
Pl switch the machine off and put 2-3 pounds of pressure with your palm on the keyboard closer to the spacebar.. this will fix it..
it is caused by the weakening of the adhesive of the wires below the keyboard.
Long term option - get the keyboard opened by the an professional and cleaned properly..and fixed back neatly...
