SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri,
I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio.
To replace the bulb:
1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder.
2. Carefully pull the bulb out of the holder and replace with the spare bulb.
3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
SOURCE: I have a model 40018 electronic clock. This clock
if you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
