Ryan Breisch Posted on Sep 30, 2018
When my radio is in SAT mode and I don't want to see the song/artist information, I just get a blank screen on the right side instead of the Sirius channel logo. Do I need an update? If so, how?
5 Related Answers
Al42
Al Klein
  • 72 Answers
  • Posted on Aug 20, 2008
SOURCE: Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Anonymous
  • Posted on Dec 09, 2008
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Anonymous
  • Posted on Jun 23, 2009
SOURCE: Sirius Starmate 4 - locks on the "Sirius: screen
with starmate 3 press at same time menu +memo+band with the radio on (with sirius screen only)
Anonymous
  • 4 Answers
  • Posted on Feb 13, 2010
SOURCE: my sirius sportster ( SP-R2 ) satelite radio
did you try going into the menu and increasing the volume output
Anonymous
  • Posted on Feb 28, 2010
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
How do i fix 2014 nissan altima radio song and title display
What do you mean by "fix" the display, is it not showing it? If so- my Nissan Altima has not been displaying Sirius XM Title and Artist for months. After much searching of the internet, I finally found an answer that worked! Just be sure to write down your radio/sirius presets before you reset the radio - it'll clear them all (and the time). The answer is here- http://incodesystems.com/Troubleshoot/Cars/RadioInitialize.htm
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
1helpful
I have a 2008 dodge ram slt and cant get information displayed on the screen,song names and such through sirius radio.Do they all display or maybe the model i have dosent.Thanks Albert.
The information as to what is playing is part of the data stream sent by Sirius, and I've never seen a satellite receiver that does not display this information. If this is a factory unit, information on its operation should be in your owners manual (and your dealer is there to help you). If this is an aftermarket radio, you ought to have an owners manual which should describe how to change the information displayed on the faceplate. Either way, the unit should give you full information about the data stream it is receiving. If not, something is amiss and may fall under warranty coverage.
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
Sound issue in Sirius sat mode only
Do you have the Built in Unit or not?
2answers
When I rip a CD onto Windows Media Player, it comes out, 1. 2. .3 ...10. How Can You get the songs to be printed instead of numbers representing the songs.
Before you select to rip the songs, edit them by renaming them - song - artist - album etc... then rip the music. Right click and select edit, then rename, press the tab key to go to the next selection artist etc.. and rename. You can also rip the music then go online to let media player find the details, but they do not always find the right details for the correct albums, so I always rename my albums myself
I hope this helps
How to hook up the sirius stratus 5 radio in my 2008 rav4?
I have sirius installed in my 2008 RAV4 JBL system.
There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
Sirus radio
I had to replace my Sportster because it was overheating and caused it to loose signal.
3answers
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
