Lands Phones Logo
Steve Manning Posted on Sep 30, 2018
De-register Vtech IS6200 headset from CS6919 base and register the IS6200 headset to Vtech DS6621 base.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 16, 2009
SOURCE: How to I reset the base for a Vtech VT-2431
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then just re-register the handsets...
Testimonial: "This works perfectly!!! I don't know how you found it, but GREAT JOB!!! THANKS!!!"
Anonymous
  • Posted on Nov 19, 2010
SOURCE: Vtech CS5113 won't show on headset or base there is a new message
I have a CS5113 new 5.8GHz phone. It was not using some time. After that when i plugged , charging led is glowing on phone. it was charged 16 hours. but no display on phone. Please suggest the remidy.
Anonymous
  • Posted on Jul 14, 2011
SOURCE: How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Anonymous
  • 1116 Answers
  • Posted on Aug 10, 2011
SOURCE: How do I de-register the
To de-register all handsets
1. Press and hold HANDSET LOCATOR on the telephone base for about 10 seconds (until the IN USE light turns on and starts to flash), then release the HANDSET LOCATOR button.
2. Immediately press and release HANDSET LOCATOR again. You must press HANDSET LOCATOR while the IN USE light is still flashing. (The light flashes for about seven seconds. If the light stops flashing, pick up the handset and place it back into the telephone base, then start again with step one above.)
3. The handset(s) will show CONNECTING... and it will take about 10 seconds to complete the de-registration process. ALL handsets will show NOT REGISTERED if de-registration was successful.
Anonymous
  • Posted on Oct 19, 2012
SOURCE: how do you deregister vtech ds6401 handset without the base?
Enter the following on the handsets you want to deregister: *331734#, followed by the left soft-key (the key labelled "-" at the top left of the keypad).
One handset on Vtech CS6919-2 has a loud buzz. I bought one CS-6919 to replace but but I cannot register it?
i can,t find my imei # for my vtech cordless landline phone. model #is cs6919-2 & the s/n is uf 203447732 all i can on the is these two numbers.i need the imei# to get it turn back on.can you help me please,please.please get to me [email protected]
Vtech headset IS6200 keeps saying out of range and it will not pair to my vtech phone
Please double check that any battery in the phone has been updated within 3 months.
Vtech also suggests using an outlet not controlled by a switch.
Otherwise, please take time factory reset your Vtech device and check for the error again.
Thank you.
Can I link my iPhone to vetch cs6919-25 phone
No, the VTech CS6919-25 does not link to a cell phone via Blue-tooth or any other method. It is strictly a landline phone (POTS - plain old telephone service) with the handset/base transmission frequency at 1921.536-1928.448 MHz. You can find the features and manual for the cordless phone system on the product page: https://phones.vtechcanada.com/en/pd/3711/CS6919-25-2-Handset-Cordless-Phone-with-Caller-ID-Call-Waiting . See the Support * Manuals tab. The current link to the complete user guide is https://phones.vtechcanada.com/media/products/CS/CS6919/CS6919-X_CA_WEBCIB_V3_20170223.pdf .
I hope this helps.
How to unblock a Vtech cordless phone with blocked caller the model number is:CS6919
With the handset in standby mode, press Menu (on the right below the LCD screen). Use the Up/Down arrows to navigate to Call Block. Press Select (the same as Menu). Navigate with the Up/Down arrows to highlight the line Block List and press Select again. Navigate to the line Review with the Up/Down arrows and press Select. Use the Up/Down arrows to navigate to the blocked number that you wish to delete. Press the Mute/Delete button (the center button below 0). You should hear a confirmation tone and either the next number in the block list or list empty should appear on the LCD screen. (You can't delete the entire list at once.)
The procedure to delete a blocked item in the Call Block list is given on page 21 of the full manual. The manual is available from VTech on the product page: https://www.vtechphones.com/store/pd/3370/CS6919-Cordless-Phone-with-Caller-ID-Call-Waiting . The direct link to the manual is https://cdn-media.vtechphones.com/products/CS/CS6919/CS6919-X_WEBCIB_V4_20160224.pdf .
I hope this helps.
2answers
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
1helpful
2answers
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
27helpful
5answers
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
1helpful
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
