Cameras Logo
G
Gail Foss Posted on Sep 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get to set up menu to change date and time
I need to change the date and time on my LUMIX ts60 and cannot get to the clock on the menu button.
Ron Baird
Level 2:
Loyalty:
Visited the website for 30 consecutive days.
  • Expert 133 Answers
  • Posted on Sep 29, 2018
 Ron Baird
Expert
Level 2:
Loyalty:
Answers
133
Questions
Helped
54432
Points
304
Maybe this manual?
https://www.manualslib.com/manual/747846/Panasonic-Lumix-Dmc-Tz60.html
5 Related Answers
Anonymous
  • 515 Answers
  • Posted on May 21, 2008
SOURCE: Tomtom Xl date and time settings
In v7.xxx software version, (you dont tell wich you have);
If all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 8/8, adjust time....
If not all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 3/3, adjust time.... While your there, tap Show all menu options.
Anonymous
  • Posted on Jan 08, 2009
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Anonymous
  • Posted on Apr 07, 2009
SOURCE: Manual Information/Owner Guide
In order to toggle display of Temperature, Seconds, Day of Week, and Month, hold + and press Set once. Release and repeat to move through the various display configurations.
Anonymous
  • Posted on Mar 14, 2010
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Steve
  • 3290 Answers
  • Posted on Jul 02, 2010
SOURCE: How do you set the time, date, and alarm?
TIME: Depress the time button and hold until digits flash. Push the right arrow until the time shows the correct time.
DATE: Depress the date button and hold until date flashes. Push the right arrow until the digita display the correct date.
You can download the manual below:
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Please rate this reply if you found it helpful
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
How to set clock on Genius DVR-530
With the MENU button you go in the menu. Buttons UP and DOWN you browse through the menu options. In your case, in order to set up the clock, you press two times the button MENU, in order to get in the so-called "next menu". Once you are in the "next menu", browse with DOWN button, untill you get to DATE INPUT option, then RECORD button to get in the options and then you choose SET. From there you can choose the YYYY/MM/DD format and values and the last option is the clock. With UP and DOWN button you choose the date format and with the RECORD button you browse through the options of the calendar and the clock . With UP and DOWN buttons you can change the values.of each catergory and change the clock.
2answers
Why does a photo display with a wrong date in Lumix Simple Viewer
Once the photo is date stamped that is a done deal no changing it.
1helpful
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
4helpful
How Do I change the clock setting on my Finepix S4000
Press the MENU/OK button to bring up the main menu. Press cursor-left then use cursor-up/down to select the wrench/SET icon. Press cursor-right then use cursor-up/down to select DATE/TIME and press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change them. Press MENU/OK when done.
The full instructions are in "The Setup Menu" and "Basic Setup" sections of the manual (pages 98 and 14 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s3200s4000series_manual_01.pdf
1helpful
3answers
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
2answers
I want my pictures has the date on them when i downloaded to my computer. How to set this function? Sorry for my bad english.
Press [MENU/SET]. Press up/down to select [CLOCK SET]. Press up and down to set time. Under Appearence set date, time and the display order for the date and time. Press [MENU/SET] to close the menu.
You can read more about this in the user manual, page 19: http://panasonic.com.au/content/library/files/F002107.pdf
2helpful
2answers
Manual too difficult
It seems to me, after reading the Operating Instructions, that it's not possible to stamp the photos automatically while taking them (EXCEPT for when stamping TRAVEL DATES - see below).
What you can do is enter the Play mode, the stamp the photos manually- 1 to 50 photos at a time.
To do this, kindly look on pages 66-67 for detailed instructions (with illustrating images).
Be sure to set the correct time and date prior to stamping the photos. Look on page 16 for further instructions.
If you're taking pictures during traveling, you can set TRAVEL DATE, which will also have a reference to the day number of your travel (page 48).
Hope you'll find my information useful...
Good luck,
Pelu.
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Clock slow
Set the date and time To set the date and time displayed on the BlackBerry smartphone, complete the following steps:
  1. In the Clock application, press the Menu key.
  2. Click Options.
  3. Click Set Time.
  4. Set the date and time.
  5. Press the Menu key.
  6. Click Save.
Retrieve the date and time from the wireless network To retrieve the current date and time from the wireless network, complete the following steps:
  2. Click Options.
  3. Click Set Time.
  4. Set the time zone in the Time Zone field.
  5. Perform one of the following actions:
    • To retrieve the date and time from the wireless network that your BlackBerry smartphone is connected to, change the Date/Time Source field to Network.
    • To retrieve the date and time from the BlackBerry® Infrastructure, change the Date/Time Source field to BlackBerry.
  6. Press the Menu key.
  7. Click Update Time.
  8. Press the Menu key.
  9. Click Save.
Note: To set the time manually, change the Date/Time Source field to Off.
Top Lumix Cameras Experts
Ngoro
SmartAviator
SmartAviator
Are you a Lumix Camera Expert? Answer questions, earn points and help others
