I have a problem with paper skew. If the document to be printed has margin lines, these do not line up with the edge of the paper. I've cleaned the rollers and tried several types of paper. The problem still exists regardless of using paper tray or the manual feed.
Any ideas?
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
SOURCE: Dell Laser Printer model 1700
I'm having the same problem. The arm with the wheels will not drop down. any suggestions?
thanks
SOURCE: Will not print
This usually happens when the paper tray is set to the incorrect paper size.
This printer determines what size paper is installed in it by the little "fingers" on the left side of the tray. When you adjust the paper tray, it determines how those fingers are positioned, and therefore, how the switch reads the paper size.
If the tray setting is off, even by one little click, then the machine may read the paper size as other then letter. If this happens, you send a letter size job to the printer, and it doesnt think it has letter size paper, it will tell you to put letter paper in the MPF feeder.
If the tray is definately set to letter, but the machine still thinks it does not have letter, then the tray or the switch that reads the tray is defective, but 99% of the time it is just the tray is not set correctly.
The MPF door can be open or closed 100% of the time with NO EFFECT on how the printer works.
Testimonial: "Absolutely useful although I didn't see it when I worked it out by my own."
SOURCE: Dell 5100cn Paper Tray Won't Feed
i think you need to look your pc maybe something wrong inside your pc..try to do something for your dell..
SOURCE: Dell Photo 926 printer no longer feeds paper correctly
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
