Where to access fuses for cig lighter
SOURCE: I NEED TO CHANGE A CIG LIGHTER FUSE IN MY 1 SERIES
under the bonnet in large black plastic box
SOURCE: 2006 VW Jetta 2.5,
For 2006 VW Jetta 2.5, cigarette lighter fuse 20A (yellow) is placed in the fuse box on passenger's side. See picture below:
SOURCE: fuse box location 2005 toyota corrolla found one
It is on the drivers side. Find the small coin collection drawer to the left of the steering wheel, the fuse box is located directly behind it. Just open it then lift and pull to remove the coin drawer and you will reveal the internal fuse box
SOURCE: where is the fuse for the cig lighter on the 650I
It is in the trunk in front of the battery. It is fuse number 87
SOURCE: fuse location 2003 nissan altima
On the bottom left side of thedashboard, there should be a little door, pull it out and all the fuseswill be there. There's an indicator map on the inside telling you whichfuse belongs to the cigarette lighter.
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Thank you for usingFIXYA!
Best regards,
Junior
Instrument Panel Fuse Block
The instrument panel fuse block access door is
located on the driver's side edge of the instrument
panel
The fuse is marked
"AUX PWR" That is the 2nd fuse from the top in the far left row of fuses, the fuse above it is marked "REAR SEAT".
