Radio Communications Logo
Maxie Eubanks Posted on Sep 28, 2018
My V8 Interphone bluetooth wont charge - Radio Communications
1helpful
My Bose Bluetooth will not charge. It was working great last week. It just stopped charging.
Hello Janine Land,
I would like to recommend you to try a factory reset: with the headset turned on, press and hold both Volume buttons and Call button for 10 seconds until the indicator light is steady blue. Have you tried with different charger?
If not able to turn ON with another charger and not able to perform the factory reset, then the only option will be to replace the device.
Regards,
Lester S.
Motorola support
Icandy bluetooth headphones wont turn on but it will charge help??
Sir i have a icandy freedom 180 headphones but i dont know how to charge them. It does not have any charging except for Aux port thanks. Kindly explain it with detail how to charge them thank you
I have two interphone headsets that we have used for 4 years. We have begun to only have battery life for 2-3 hours. Is there a way to change batteries? Any help will be appreciated. They have...
With the BT Interphone that I have (~4yrs), one unit's battery would last <1hr. I carefully cut the rubber case along the bottom mold mark to remove the circuit board. The battery is a 3.7v 600 mah lipo. These are available from a variety of hobby shop sources, but are 650mah. $7-15 ea. Very careful cutting of the rubber case and minimal heat soldering is critical in installing a new cell. I'll use 3m weatherstrip adhesive to close it up.
Otherwise a complete new 3rd generation BT set-up is about $90 online. Mine still works good though.
1helpful
Bluetooth mp3 saving as messages?
Take it to Verizon it is very uncommon for that problem to occur. Verizon is the only one who could help. You are welcome.
1helpful
Tomtom 930 will not pair with Interphone 4
Sadly, it's not possible to do what you want.
The lower cost, non bike specific units only have limited BT capability - so that they can act as a handsfree for a phone - which is what Interphone does, so there's fundamental incompatibility.
The best units with Interphone are Garmin Zumo 550 (NOT 660) or TomTom Rider 2.
Only one person can hear the gps (and the range is only 10m from Interphone to gps)
Your best bet could be to get phones with gps capability - it's free on some of the new Nokias.
1helpful
Sony ericsson t610 is not charging
if the chocking coil that is placed bet charging fuse and charging input pin of UEM(universal energy management) is not working properly the set wont charge or else if protection anode is short circuited also device wont charge
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
