Most of the Canon printer users report that they consequently face issues with Error code 6004. This error code will be displayed on the printer's control panel. Error 6004 occurs due to incorrectly configured system settings or irregular entries in the Windows registry. Such errors can be fixed with special software that repairs the registry and tunes up Windows computer. Read the instructions given below to fix the issue.
1)The probable reason for the 6004 error code can be because the connection between your computer and the printer might be lost. Hence, check the transmission cables.
2)Ensure that the USB cable is not damaged, broken, or fold.
3)Check if the issue persists. Replace the printer driver.
4)Download and install printer driver using the installation disc that comes with the printer's shipping box.
5)Check if the print spooler functions properly. The printer spool service can be choked on bad data and terminated or stops running correctly.
6) It is always necessary that you reset the printer. Resetting the printer can fix most of the error codes.
7)Turn off the printer.
8)Disassociate both ends of the USB cable from the printer's control panel and the power outlet.
9) Wait for 15 seconds and replug the printer.
10)Turn it back on.
11)If this does not solve the issue, contact your nearest Canon service center to request a repair. For Support Call our Toll-Free 1-866-293-9220
SOURCE: hello its showing an error
Possible Paper Jam, Clear all paper from printer and power off. Turn printer back on, load paper and wait for it to warm up. Also, When the printer is off try Re-seating the Ink cartridges.
Try the site.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830#ServiceAndSupport
Manual for it, or read the one you got with it, it should list Error codes.
http://gdlp01.c-wss.com/gds/2/0900002862/01/mp830_ug_us_v4.pdf
