Microwave Ovens Logo
A
Aimee Goldberg Posted on Sep 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Miele steam oven gives me a Fault 20 whenever I try to do steam cooking. The regular convection cooking works fine. I've already descaled. How do I fix this? Thanks!
x-ray man
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Sep 26, 2018
x-ray man
Expert
Level 2:
New Friend:
Answers
43
Questions
Helped
16480
Points
110
I would test the water you're using, I suspect it's not distilled even if it's labeled as such. The boiler may have to be re-claimed by a tech. if descaling and changing H2O sources don't correct the problem.
5 Related Answers
Anonymous
  • 111 Answers
  • Posted on Nov 21, 2007
SOURCE: Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Anonymous
  • Posted on Sep 13, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
hi i have the panasonic combi and on the microwave it will work for a few seconds and then stop and on the screen it shows h98 please help
Anonymous
  • 136 Answers
  • Posted on Sep 24, 2008
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Phil Sciacca
  • 36 Answers
  • Posted on Jan 08, 2009
SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 30, 2009
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
2answers
How to use convection oven
Use just like a regular oven. Convection just blows the hot air around, so cooking can be faster. Search on google the differences between convection and baking.
Why does my convection microwave ovens fan keep running long after it has finished cooking
There are 2 reasons :
01.Because the high temp. used to cooking must chill down.
02.To exhaust the remains of steam that could lead to premature rust of the oven
How do I unlock Miele steam oven when it has not been descaled within the 10 reminders
If you would like to get some details about microwave oven repair and service then check the following link.
http://electro-medical.blogspot.com/
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
2helpful
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
1helpful
Microwave has stopped heating, yet grill and convection oven still work.
A model number would have helped, but I can give you a generic answer.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
2helpful
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
I cleaned our oven, and now it is not heating up. The convection oven works fine, but the microwave will not heat. It comes on fine, but doesn't cook. What are the possible solutions?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
I've just bought a microwave/grill/convection oven combi but the manal isnt very comprehensive. i'm not sure what i can use to cook in with the convection oven function. can i use metal in there? eg. can...
Yes.
In convection mode, you can use anything that's oven safe. Anything you would use in a regular baking oven in other words.
There's a very interesting and helpful article on convection cooking here, and you can find more tips here.
Top Miele Microwave Ovens Experts
vince
john h
k24674
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
