I want to scan document on my MP250 series
SOURCE: Canon MP250 printer scanner in a canning mode
Go to Device Manager at USB Controllers and disable Standard Enhaced PCI to USB Host Controller. If you can't find exactly this, disable the one with the word Enhaced in it. Right click it then click disable.
SOURCE: getting error code 2101 when scanning a document
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
SOURCE: CANON MP250 SERIES PRINTER NOT WORKING SHOWING
PASTE WHITE GREECE ON HEAD MOVEMENT POSITION.
SOURCE: How do you fix error code E04 for a Canon Mp250
hi good morning don't worry this error code tell you to change your BLACK ink cartridge. have a nice day
SOURCE: when i try to scan
Do u have enough ink?
For Canon, if you do not have ink in the cartridge, printer won't let you use the scanner as well.
It's all under same system so either black or color cartridge is short of ink, it naturally happens.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
