Changed drum unit and developer unit. but same problem.
Do you have issues with your printer printing only in the solid black image? Scroll down this webpage to save hours of online search. We have enlisted the best solutions to fix the issues with your Canon ir33000 printer.
1) To begin with, check if the Canon ir33000 printer supports color ink cartridges.
2) Reinstall the imaging unit. Take the toner cartridge out first and then the imaging unit.
3) The imaging unit is a drum which is an integral component that is present on a laser printer. It transfers ink to the page during the printing process.
4) Replace the imaging unit if it is required.
5) Resend the print job to check if the issue is resolved. for Support Call Our Toll-Free 1-866-293-9220
SOURCE: Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
SOURCE: Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
SOURCE: solid black line at the left side of paper after reset the drum
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
SOURCE: have black smudge line in middle of paper have new toner and drum
Try taking out your toners, and on the drum you will see a green button which you can slide from side to side (it's on each of the colored slots). Make sure you put the the white plastic cover up and then it will slide. I hope this will help you.
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
