I used a flat antena and nothing happened. Can someone help me, please? Thank you! I would like only (at least) loco channels.
SOURCE: ssl2006 sylvania TV goes dim and turns off within 5 seconds when turned on
POWER SUPPLY SHUTTING DOWN
SOURCE: I have had my 40 inch Samsung LCD for
I have come across that problem about 8 times in the past, only solution to your problem is to have the main board replaced.
SOURCE: is the rca true flat tv able to be used by putting
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Testimonial: "thanks for the help."
SOURCE: i have a sylvania tv, i dont have the remote, i
I may have the same problem on my Sylvania 6420FE. With the remote broken, there seems to be no way to switch between the TV antenna input and the digital input (rabbit ears --> digital converter --> antenna input)(DVD player --> digital input). You'd think there would be a way to do it in the menu system, but no, must use "input" button on remote.
