SOURCE: RadioShack PRO-94 Scanner
This sounds like you're monitoring an EDACS system and are not in trunking mode (search or scan). EDACS systems transmit those tones to make scanning less enjoyable. Read the manual to find out more about programming and monitoring trunked systems.
SOURCE: need to unlock our radioshack
Easy to use right out of the box!
Explore
preset frequencies used for non-trunked police/fire, aircraft, marine,
NOAA weather and more. Just attach the antenna, switch it on and touch
one of five buttons. With just two keystrokes, you can store a
frequency you find in the 200-channel memory for later scanning or
monitoring. You can also search for activity in frequency ranges you
specify or program known "action" frequencies on the keyboard.
SOURCE: how do i remove all codes from my radioshack
For a full reset, turn the scanner off and then power it back on while holding the 2 and 9 keys. CLEAr will appear on the display. NOTE: this will clear all frequencies and any other information that you have programmed into the scanner.
To clear/erase a single channel just enter frequency 0.0
Need the manual? You can download/print it here:
http://www.rigpix.com/rs-realistic/radioshack_pro76_manual.pdf
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
SOURCE: want to no how to program scanner to pick up phone calls.
Sorry, but it can't be done, for at least two reasons. Cellular bands are out of the tuning range of your scanner, and it cannot be modified to receive the cellular frequencies. Virtually all cellular signals are now digital, and the PRO-95 is an analog-only scanner.
Bill B
Testimonial: "the imformation was very helpful! thank you."
SOURCE: i have a radioshack pro-97 can this scanner be
The PRO-97 will support some rebanded systems, but not others. For a discussion on the topic, follow this link to the related forum on RadioReference.com:
http://forums.radioreference.com/radio-shack-scanners/21688-gre-team-pro-97-rebanding-status.html
Bill B
