Question about Electrical Supplies
I let my predator 4000 generator cool for 5 minutes before refueling and now it won’t start. Did I break it?
6ya staff
SOURCE:
Anonymous
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: my 18in homelite saw starts ok, cuts fine
Loosen the fuel cap when you shut it down tighten it before you restart. If this fixes it you have a plugged fuel vent. HTH
Lou
Posted on Oct 07, 2009
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
Anthony Pattay
  • 14 Answers
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
Posted on Oct 05, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: My Coleman Powermate 7000 won't
I not you said you "checked the oil level" My experience with most portable generators is that they must me positioned as level as possible and the oil level must be fully serviced as full as you can get it without oil leaking back out of the dip-stick hole on units WITHOUT an extended dip-stick. Unless those conditions are met the low oil level sensor ends up presenting a false low oil signal and it grounds out the ignition. DO you have Spark at all? If you do have spark and it still does not run respond with the MODEL number off of your ENGINE and I will show you where the main fuel jets are located so you can make sure the orifice is clean.
Some units have a fuel solenoid that presses into the main fuel jet recessed area and shut off the fuel to the carb. This is also an area that debris causes havoc.
Thanks,
Kelly
Posted on Aug 29, 2011
I have a Predator 4,000 generator that wont stay running. I followed all recommended instructions before trying to start it. It ran first time for about two minutes and died.same thing every time.
sounds like a fuel flow problem.Pull the fuel line off at the carb and see if fuel flows well when you turn the gas on.If the fuel is flowing to the carb,you will have to remove the float bowl off the bottom of the carb and check for fuel flow through the needle and seat which the float controls in the carb.If fuel flows well through the needle and seat and the float words well without binding, next is to clean the main jet which may be plugged.Ethanol in the fuel these days can cause problems in these areas.ALWAYS shut off the fuel in all small engines and let the carb run dry when storing small engines for any length of time.
Feb 07, 2018 | Cars & Trucks
Predator 3200/4000 generator makes lights flicker won't run microwave adjusted carburetor worked fine turned it off started it the next day lights flickered again not enought power to run microwave.
hi
take look at the governor ( it situated very close to the carburettor with some light springs attached to it ) it an automatic throttle device which open the throttle when there more demand of electric power
Jan 11, 2018 | Electrical Supplies
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Our onan generator ran out of gas. we refueled but the generator will not start. i gave it a shoot of starting fluid, the generator fired and run for a second, then died. could it be a cogged fuel filter?...
No, not the filter, you will need to try to prime the carb better then with starting fluid, pour some gasoline down the carb, you may have to do this a few times, but everything will fire back up again once you get the air out of the system
May 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
77 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
