SOURCE: connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
SOURCE: technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
SOURCE: technics eq sh-ge70
According to Panasonic the manual is only available for purchase (paper/CD-ROM) 1-800-332-5368
