You have a failed board or sensor. Here is link to error codes.
http://www.hvacdist.com/Tech%20Svc%20Bulletins/AMANA/Comfortnet%20Fault%20Codes%20&%20Descriptions.pdf
SOURCE: I have a Maytag A/C
Why should I tell you how I fixed the problem for free if you can't even tell me how to solve this problem for free. I just wanted to know what the error code meant and if it can be fixed or is the unit junk.
SOURCE: amana wall ac unit
Try using your remote to turn it on. This is what worked for me. Hope it helps!
SOURCE: error code EE on a panasonic window unit
EE- High pressure problem. Clean condenser coil and check amps. If gradually high replace capacitor.
SOURCE: I have an AC unit
According to the Owner's Manual if the Error Code flashes "06" the O.D. coil Temperature > 175 Deg
F for 2 consecutive minutes. (Heat Pump models only).
The action taken by the unit is Alternate flash set point and error code. Shut unit down for 5 minutes, then try again 2 times, if fails the 3rd time, then shut down unit.:
All of this is can caused by several things:
• Dirty filters
• Dirty coil
• Fan motor failure
• Restricted air flow
• Improper refrigerant charge
• Restriction in refrigerant circuit
The dirty filters, dirty coil and restricted air flow you can troubleshoot and solve yourself. The reaming ones should be handled by a an authorized service technician.
Here's a link to your Owners Manual, that you can download and print for future reference.
http://www.ajmadison.com/ajmadison/itemdocs/92008705_9-07_PTAC_IO_manual.pdf
Hope this helped to to troubleshoot and solve the problem . Please let me know. Thanks.
Model ACK089R
