Cannot be stopped without disconnecting it.
SOURCE: Toro Rake and Vac model #51573
I was able to find PDFs of manuals from the manufacturer directly at this site: https://homeownersolutions.toro.com
Just run a search based on your model. In this case, simply type in 51573 in their search box. You get access to an online interactive manual and also makes PDF available.
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
SOURCE: 1996 Dodge Grand Caravan wipers continue to run
The multi- function switch (turn signal switch) Your wipers are control by this switch. This problem is very common on dodge and chrysler with this switch failing.
SOURCE: I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: I have a 51592 Rake and Vac Toro blower.
I had the same problem - then the motor went shortly afterwards. time to by a new one - frustrating because I've only had it for a couple of years.
