There are two separate belts underneath. The upper belt goes to the hydrostatic transmission. The lower belt goes to the cutting deck. Please be sure about the belt being fine. Unless the belt is new, the belt could be stretched. The pulleys and tensioning devices will need to be inspected for wear, damage and function.
SOURCE: I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
SOURCE: change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
SOURCE: I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
SOURCE: i engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
SOURCE: Mower runs fine but shuts off when the blades are engaged.
This sis a micro switch issue, start by checking/replacing the seat switch, make sure the block connecter is fully pushed home onto the micro switch.
