SOURCE: Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
SOURCE: i have an 18v dewalt hammer drill dc925 and cant
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Before the game begins, a wall of 24 bricks (plus one "Knockout" brick) is constructed. A template is provided to assist where the bricks should be placed in the wall. These bricks can be 1, 2, or, 3 blocks wide. The bricks are made of clear colored plastic. The 25th brick, also known as the "Knockout" brick (colored solid black in the Milton Bradley version and solid blue in the Hasbro version) is three blocks wide, and is placed on the top of the wall, directly in the middle. The template shows exactly where to place this brick as well.
Players first must roll a special die that has four colors on it and two stars. If a color is rolled, the player must knock out a brick of that color, out of the wall. If the player rolls a star, the player may knock out any brick they wish (with a few exceptions, see below). Players take turns using a motorized hammer known as the "Rammer Hammer", in an attempt to knock out the specified brick out of the wall, without making the wall collapse, OR making the "Knockout" brick fall off the wall. If a player is successful in knocking out the brick, without the wall collapsing, or the "Knockout" brick falling off the wall, they must put the brick back, on the top of the wall. Each player thereafter must accomplish the same task.
The rules for hammering are:
A player is allowed an attempt to make the wall more stable by using the hammer to stabilize the wall before they commit to hammering out a brick, but once a player starts to hammer a brick out of the wall, they can not change their mind.
If at any time during a player's turn, the wall collapses, or the "Knockout" brick falls off the wall, that player is eliminated from the game, the wall is rebuilt, and play starts again with the next player in line.
If only one player remains, they win the game.
