I need to clean my self clean oven
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
SOURCE: I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
