Question about Dell Office Equipment & Supplies
Object inside dell v510 printer how do I open printer to remove object
6ya staff
SOURCE:
Mix-it-up
Mix-it-up
  • 832 Answers
SOURCE: unable to print
press menu then start mono then 4x arrow-up. machine will be in maintanance mode. what error code does the machine display?
to leave the maintanace mode simply unplug machine from power and reconnect again.
Posted on Nov 07, 2007
Tirzo
Eric Dacion
  • 94 Answers
SOURCE: Foreign object
It appears as though the printer hardware itself is malfunctioning and will require service.
Posted on Jun 11, 2008
Anonymous
SOURCE: My Epson Stylus DX5000 won't work.
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Posted on Apr 16, 2009
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
SOURCE: both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Posted on Jun 10, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Dell V510 printer worked fine wirelessly until we got a new Belkin Router
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
Posted on Jul 15, 2012
Foreign object inside the spinner how can i remove it
Just make sure you take everything out, no paper, no tray, etc... hold the printer with you hands and shake it until the foreign object falls out.
You can also disassemble the printer, it's really not that hard, take the foreign object out, and put it back together.
May 10, 2016 | Office Equipment & Supplies
Small object caught inside dvd writer
Remove the drive. Use paper clip to open drawer. Turn every which way to get object out. Last resort take covers off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Mar 31, 2014 | Samsung DVD Burner SATA Model SH-224BB -...
Dell v510 printer
Go to 'printers and faxes' in control panel, make sure the Dell v510 is the 'default printer'.
Nov 22, 2013 | Office Equipment & Supplies
Jul 14, 2012 | Dell AllinOne Multifunctional (v515w)...
My Dell V510 printer will not print. I have checked the cables, I have checked the ink cartridges, I have unplugged the power supply, I have re-started the computer and nothing helps. Items in the print...
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Can you copy a document under the glass? B&W and color?
What is the correct model of the printer? V505 or V515? Dell does not have a V510.
You can try reinstalling the printer using the instructions located at...
Dell V505 & V505w All-In-One (PRODUCT) RED™ Printer owners thread (W7)
Dell V515w Wireless All In One Printer - (RED) owners thread
Virus programs and firewalls will block communications.
Rick
Apr 19, 2011 | Dell AllinOne Multifunctional (v515w)...
Paper Jam Alarm - but cannot find any jammed paper?
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't open Epson DX5000 to remove object stuck inside
sounds a little draconian, but sometimes if you invert th peinter and give it a tap, the foreign object may fall out. Just don't leave it upside down too long!
Dec 15, 2008 | Epson Stylus Multifunction Inkjet Printer/...
EPSON R220 - Open
HI,
Do you know what it was that fell inside?
Thanks,
Worldvet
Sep 26, 2008 | Epson Stylus Photo R220 InkJet Printer
Printer will not take paper, makes noise but will not take
check if the rollers (that pull the paper inside are moving).
Oct 20, 2007 | Canon PIXMA iP90 Mobile Printer
How do i get inside the printer to retrieve a foreign object
Switch of the printer remove all the connection ..Lift the printer upside down and shake it ,, the object should fall...
Oct 17, 2007 | Lexmark X5470 All-In-One InkJet Printer
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
