IF YOU RAN OUT OF GAS, THE LINES MAY NEED TO BE PURGED OF AIR. dISCONNECT THE GAS FLEX AND TURN THE GAS ON TO PURGE THE AIR FROM THE LINE. dO THIS UNTIL YOU GET A STRONG SMELL OF GAS. aLSO, WHEN YOUR UNIT TRIES TO LIGHT, BUT THERE IS NO GAS, IT WILL TRY TO LIGHT THREE TIMES. aFTER THE THIRD ATTEMPT, THE UNIT LOCKS OUT. yOU MAY NEED TO RESET IT BY UNPLUGGING IT, OR IF IT IS HARD WIRED, JUST TURN THE BREAKER OFF FOR 10 SECOINDS AND THEN TURN BACK ON. tHIS WILL RESET THE GAS VALCE TO RELIGHT. gOOD LUCK!
SOURCE: I don't know how to restart my old bosch water
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
SOURCE: bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
SOURCE: bosch 13b will not ignite/have gas to unit-no pilot gas
The gas regulator might have failed , not allowing any gas to flow, or the draft regulator is failing not allowing the burnt air anywhere to escape and for no new air to enter for burn.
SOURCE: pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
SOURCE: We have a rinnai infinity
Below is a website link inwhich you can copy and paste to a new browswer window. When you see the page come up go down about midway and you will see the link,
click onto that link for a full service manual for your water heater
http://www.google.com/search?hl=en&q=rinnai+infinity+26+hot+water+system+manual&aq=f&aqi=&aql=&oq=&gs_rfai=
