Luxor TV, maybe 3 to 4 years old.
Check the power supply for burned-out electrolytic capacitors. The power supply board has a two- or three-wire cable going to the power cord connector, possibly through a power filter module. The picture below shows burned-out capacitors with domed-up tops next to some that are good (the tops are flat). I recommend replacing bad capacitors with Panasonic FR-series parts; these have a good combination of power handling ability, longevity and price.
Failing capacitors will work for a while, but as the power quality deteriorates, it gets harder for the set to operate, just as you have observed. It is possible that there is another part with a thermal problem (quits working when it gets warm), but this is the most common failure mode.
SOURCE: No picture but audio OK
m1013 was absolutely correct! I ordered the part B-00008166 from ViewSonic in May and it finally arrivrd in August. (75.48 Shipped). It took about 20 minutes to replace the supply board! Thanks for the great info!
SOURCE: philips TV sound on but picture fades to black
Philips TV. was working fine but now picture fades to black. sound is on. If we turn unit off/on picture returns...but will fade again. can fade one minute later or ten minutes later...unit id about 5 years old. 29 inch. (tube flat screen)
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
SOURCE: The TV switches it self off
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If your TV keeps turning itself off, I would advise firstly
checking the power cable connected to the back of the unit to make sure it is
secure.
Please also disconnect everything from the TV apart from
thee power cable as it may an external device that is causing the problem.
If there are touch buttons on your TV, make sure they are
not touching anything and they are clean.
Remove the batteries from your remote control as this could
also be turning the TV off.
SOURCE: Screen keeps going black, green light blinks, then screen returns
Lamp- Mats has them 1-800-628-1118
