Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
SOURCE: white horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
SOURCE: horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
SOURCE: black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
SOURCE: 2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
