SOURCE: I have a pioneer VSX-1019AH-k receiver connected
Hi, I have the same Pioneer receiver, and the same TV, with a Harmony (p.o.s.) remote - and the closed captioning is not available when I select it on my remote. My problem is ever since Sunday night I have closed captioning on all the time. It's not from my remote and I have no idea how to turn it off. Any ideas?
SOURCE: My pioneer vsx-519V-k amp won't turn on. Just
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: taken delivery of 40" samsung
Make sure you have it set to wireless off in the menu or it will not recognise the ethernet port on the back even if it is flashing. Most tvs with browsers come with the wirless function set to on. Also if it has search for internet signal you could try this to get it to rec. as well.
