SOURCE: Hobart SR24C-4 Dishwasher can't drain completely
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Go to page 12.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/860F7951C087BD7F85256D36004978EA/$File/F43078.pdf
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
SOURCE: Hobart sr24h dishwasher won't get up to temp.
the water level is low (should cover the bottom of the tank about a 1/4")and the pump is starving - therefor probably not washing very well.
three things to check
1. check braided fill hose for kinks (you will have to pull the machine out if under a counter). run the machine while pulled out if possible to ensure its not kinking when you push it in.
2. pressure reducing valve-prv (if installed) on the incomming water line before the braided hose (probably under a sink). turn the screw on top clockwise to increse pressure.
TURN THE BREAKER OFF TO DO THE FOLLOWING!!
3. flow regulator (if installed) - installed under the bottom pannel at the end of the braided fill hose (about 2" long and silver). turn off water. you can simply remove it, drill out the centre or just remove the rubber peice inside.
inrease the temp by adjusting the thermostat on the right side under the bottom pannel in front of the booster.(dail is hard to see and breaker must be turned off)
remember - the machine must be turned on for several minuets to truly get up to temp.
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
SOURCE: We have a hobart sr24h dishwasher which is leaking
hobartcorp.com under service tab click parts then smart parts system tab
SOURCE: my sr24h hobart undercounter dishwasher is stuck
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
