The Netflix little red circle just keeps on going round.I have restarted my router and switch and switched my TV off and on again. Nothing helps.
Hello:
wifi , is not reliable. use Etherent cable from TV to router ! wins !
you posted TVs to Computers, so will move you.
what TV o TV model stated.
MAC, how is it connected, to your router? all that tells me is the internet works on the mac. as does its browser..
I will assume the TV shows, can not connect to local LAN , errors, (wifi in this case) gee use Ethernet cable.
not netfix login failure
not like me using 3 TVs to netflix, with a 2 TV max same time account.
Also Netflix, Hulu and Vudu all 3 no longer support
old TVs running those old streaming apps with same name.
they do not, (buy ROKU3 , wired)
The went to a far better, streaming protocal your TV does not support, but again, NO TV even stated.
By a long ethernet cable.
no distance from TV to Router stated, nor type of walls between them,(concrete /brick horrible)
WIFI is radio technology at its base) and weak signals.
you skipped test 1;
use ethernet, cable.
this proves the TV works the TV app works and that Netflix, likes all that, with one simple test.
a $10 cable, sold in all computers stores on earth.
NO TV stated, full model on the rear sticker is it.
lots of TV made in 10 years ,even older
and old is bad, in the realm of , Smart screen apps that are relics now.
I moved you to TV SAM
no TV stated. guessed.
most TVs no all, but better TV tell you what is wrong,, failed to connect your net work , local.
or tells you netflix login fails.
best is to use wired connections, forever.
CAT 5/6 cable Ethernet from TV to router,
if this works bingo, you wifi is messed up
as most are.
wifi is complex. ( IT IS SHARED RESOURCE)
TV too far from router.
using same channels wifi as your neighbors, change that in the router.
youR HOOD has to many wifi users, like in the city, (locations matter)
wifi can be a hair pulling event.
avoid it is best, or as backup to real sub lan network wired.
we use ours only for CELL backup if 4G goes dead. as one example.
we have wifi scanner here,
I run it and see OMG 50 others in the HOOD
are using my same channel
so I go to the top channel and works better.
until they read this and move up range and kill me again. (an endless game and way too few channel)
this software does not show other jamming devices.
get Inssider v3 ( and scan ) v4 costs money.
old land lines port. phones jams wifi
old baby crib monitors jam wifi.
and some toys (RC toy cars etc)
finding cause of jamming takes very expensive equipment that I do have, but do not teach.
see V4 run here, see if your HOOD is jamming your channels, that you picked.
sadly v3 is hard to find now. I have it backed up.
https://youtu.be/_pr5-JqJJ3s?t=132
SOURCE: I want to connect to my samsung tv to watch
Will / can this laptop access your home network and the web, ether wireless or wired? If you can deal with it being wired to your router all you need is a network cable and plug it in to the router. If you have a wireless home network or router, and you are wanting to hook up wirieless. you will need a wireless adapter for your laptop. The better ones are D-link, Belkin, Linksys, Cisco. I would recommend to stay away from Netgear they are not easy to work with for a first time user. These wireless adapters will plug into a USB port and once the soft ware is installed away you go, easy as that. Access your netflix account and you are watching movies. Another thing you may consider would be if you have a TV and you want to watch netflix on it,, is a Roku player. Check them out >>> here
SOURCE: We bought this tv because
Its not your TV its Netflix. Go to Netflix Watch TV Shows Online Watch Movies Online and find the support link.
SOURCE: I have a media streaming TV by seiki that is
you need to login with you account on netflix ...
Go to Best Buy and get an Apple TV for $69. (It's not aTV set. Just a little box that connects to your wifi and streams content to your T v. You hook up the Apple box, change the tv to the hdmi port you plugged it into and get your wifi connected to it. Then select Netflix and log into your account. Or wait for the new Apple to be available for $200. You can also get an Amazon Firestick from Amazon but you will like the $69 Apple TV better.
SOURCE: Signed into Netflix and circle keeps going round and round
If you have the ID and password for your Netflix account confirm your subscription on another computer.
Attempt relocating your tablet to a good WIFI location and sign on. If unsuccessful attempt a friends ID and PW. Attempt to isolate the problem.
