Question about Nordic Track Exercise & Fitness
How do I take apart a Nordic Track Audiostrider 800 to get it up some steep stairs.
4 Suggested Answers
6ya staff
SOURCE:
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: i have a nordictrack audiostrider 800 that i just
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Posted on Nov 08, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: moving nordic track 2750a pro too big to fit
Dear Sir:
You have the alternativa to fold the treadmills, and get help for another persons.
Please see the user manual from Life Fitness, and see the section how to fold the treadmill, and ready.
If you do not have the manual, go www.lifefitness.com see the customer service, go parts&manual, give you model and download for free. or to www. searsparts.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua
Posted on Feb 16, 2012
Audiostrider 600 software not working
There may be a problem with the resistance motor or the flywheel.
Nov 29, 2013 | Nordic Track Nordictrack Audiostrider 600...
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
Pedals wount move
OIL IT. IF That doesnt work go to justask.com and they will help.
Oct 30, 2012 | Nordic Track Audiostrider 800 Resistance...
Nordictrack auidostridder 800 elliptical screen dead
Chad Gilbert--
I'm having the same problem with my Audiostrider 800. Fan works, screen and soft buttons do nothing.
I dont mean to sound dumb, but where are these motor brushes? Are they attached to the resistance motor or somewhere else? What exactly am I looking for?
Any help would be greatly appreciated!!
Aug 11, 2012 | Nordic Track Nordictrack Audiostrider 800...
Where to plug in adapter on audio strider 800
you must see you instruc manual. if you do not have download fro
www.nordicktrack.com go to service customer, then to parts&manuals put your model and download. or go to www. fitness.manualsonline.com and download.
God bless you
May 20, 2012 | Nordic Track Nordictrack Audiostrider 800...
I have a Nordic Track Audio Strider 900 and I have had it for a year. There is now a very loud intermittent sound coming from the back of the machine. It happens rather randomly- but when it comes, the...
Hi We have a Nordic Track AudioStrider 900 and it is squeeking when in use - it's getting so bad that we feel we can't use it. Do you have any advice?
Oct 03, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
192 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
