Question about Sharp Microwave Ovens
My sharp microwave corusal model r-9H20(w) start button not working
Anonymous
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave works fine, but wont heat food....
I would say the high voltage rectifier diode has blown.
See http://www.gallawa.com/microtech/diode.html for help in diagnosis.
Okay, now that I see the model number, that's a US model:
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Sep 25, 2008
charlymonty
  • 3741 Answers
SOURCE: sharp carousel microwave model # 508ak has power
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Posted on Jul 11, 2009
richardcedwa
SOURCE: Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Posted on Sep 01, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: My sharp microwave oven model
Sorry to read about your problem, I hope this helps you out.
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount. 1
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
zaffarlone
SOURCE: Microwave owen SHARP Model R9H20 Digital
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
zaffarlone@yahoo.com
Zaffar Iqbal
Posted on May 17, 2011
Start button Sharp microwave Model r-1874 does not work. Solutions, please. Thanks.
  • Defective button
  • Defective door interlock
  • Defective control board
Jun 05, 2018 | Sharp Microwave Ovens
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Why my sharp r 9h20 microwave oven noyzey during operation?
You are probably referring to the cycling of the klystrom in order to maintain the power lever you have chosen. The noise is characteristic of yours and other cycling type ovens. For a quieter operation that is not "all off" and "all on" in succession, try a DC powered next time. Panasonic makes one called Inverter...maintains cooking level without switching.
Nov 10, 2014 | Microwave Ovens
How does sharp microwave r-9h20 work
All microwaves are very powerful, dangerous machines which emit electromagnetic radiation using a high frequency magnetron. Do not mess with this or it will cook your liver . Take it to an approved service department for repair or recycle it.
Aug 28, 2014 | Microwave Ovens
Sharp microwave oven r-9h20 display flash(00:00)) and no keypress action
On Sharp R-9H-series ovens, when the membrane keypad fails, as in your case, since these parts are no longer available, the oven would have to be retired.
Sorry to bring you bad news. These were great old workhorses.
Sep 04, 2011 | Microwave Ovens
Start button will not work? All other buttons work.
Most likely your key sheet has failed. The PN is:
FUNTKB079MRE0
All sources I checked say currently out of stock but ships in 7 - 14 days.
This was the best price:
http://bestbuy.partsearch.com/Model/Sharp/Sharp/R1462.aspx?p=1&z=50&c=1817d7c6f52a16787278d6493ab5937b&bs=Category&bd=Asc&ms=Category&md=Asc&k=&on=
Order page below:
http://bestbuy.partsearch.com/Part/Sharp/Sharp/R1462/Sharp/Sharp/FUNTKB079MRE0/New.aspx
Thanks for choosing FixYa,
Kelly
Aug 08, 2011 | Sharp R-1460 Microwave Oven
Start button does not work
If this is a Sharp R1500-series microwave (you didn't mention the model number but posted under that) then the most likely problems are:
- broken Start button see here
- bad door switch see here
- bad keypad or other problem see here
The service manual is here.
Mar 06, 2011 | Sharp R-1510 Microwave Oven
My sharp microwave oven model no: R-9H20 needs to be replaced with a new feather touch pannel. Is the spare part available in market. If so where can i buy it.
3 Thumbs - Helpful
Jan 02, 2011 | Sharp R-1480 Microwave Oven
Microwave owen SHARP Model R9H20 Digital START button is not working. Need Workshop address in Dammam or Al-Khobar, Saudi Arabia including phone numbers to fix the problem.
Zaffar Iqbal
Dec 18, 2010 | Sharp Microwave Ovens
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
