K
Kevin Tipene Posted on Sep 15, 2018
Jbl charge 3 won’t turn on - JBL Audio Players & Recorders
JBL Party Box 310 will not turn on?
Question edited for clarity, yourspacebarisbroken. Pleasefixit.
Question moved from Cameras to JBL Speaker.
Contact them for a warranty repair.
https://ca.jbl.com/support-product.html
Did you try the Hard Reset procedure?
https://www.google.com/search?q=jbl+partybox+310+won%27t+turn+on
Where's the so to speak amp on jbl charge 3
The controls for the JBL Charge 3 are up top and you have volume up and down, Bluetooth pair, power, play/pause, and a button to link this device to other JBL speakers. There is no skip button, but if you hit the play button twice quickly it will skip to the next song
JBL charge 4 stuck in demoo mode. How do I fix this. Also it can't turn on . when charging the power buttons turns on white and dosen't flash oor does anything.
Try doing default factory settings.
Step 1. Press the "Power" button located on the top center part of your JBL Charge 4 Bluetooth speaker. The speaker will be powered on when the LED backlight under the Power button is lit.
Step 2. Hold down the "Bluetooth" and "Volume Up" buttons at the same time for roughly three seconds. The Volume Up button looks like a plus sign. Additionally, it's important to hold down the "Bluetooth" button in the center of the device next to the Power button, as it's easier to hold down. After three seconds, the LED ring around the Power and Bluetooth buttons will briefly light up before the JBL Charge 4 powers down.
Step 3. Press the "Power" button again to turn the JBL Charge 4 Bluetooth speaker back on. The Charge 4 will instantly turn on in Discovery mode, with the Bluetooth LED blinking on and off, and the speaker making a pinging sound. This confirms that you've successfully reset your JBL Charge 4 to its default factory settings. You'll need to pair or re-pair any devices you want to play audio through the JBL Charge 4 speakers with the device.
3helpful
Any way to Factory Reset a JBL Charge 2 ?
Yes, follow this sequence:
1. Turn the device on
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
Good luck.
1helpful
Help pairing jbl charge
Put JBL Charge in pairing mode: turn on Charge. Hold down power button till it flashes red and blue. You're in pairing mode. Go to your device and find Charge and pair up. Done!
JBL Flip won't turn on
this doesnt help. how can i get back on?
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
