My CS6000i Brother sewing machine. How often should I oil it?
The owner's manual is your best source for that information. If it's computerized, you need to follow the instructions exactly.
If it's a "mechanical" machine, you can use good quality oil (I use Tri-Flow Synthetic Lube) and put a drop every place where metal rubs against metal.
I can generally tell by the change of sound of the machine when it needs some TLC. I tend toclean & oil the shuttle every 8-10 hours of sewing and do a thorough oil every 40 hours.
SOURCE: My Brother CS6000i manual does not mention oiling. Should it be?
i was able to find it at www.ifixmachines.com
SOURCE: my bobbin thread is not drawing up on my brother
If the thread is being trapped in the bobbin area, yes, it could be the bobbin case. If the thread goes around the bobbin case and come back up then it is probably out of time and needs to be sent to a repair shop.
Yes its the tension, however it can be tricky, and you really should have some experience working on the mechines Give us a call we can help you out.
303 770 6321
AAAA TEVA
Yes 110v in USA not 220v which is what you have put through...it is fried
SOURCE: Need a ruffler foot for brother cs6000i
try this site
http://www.gonesewing.com/servlet/Detail?no=323
