SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you
need to use the option that scans to SMB, that sends the scanned
documents to your computer on the network. You can then process
the documents on your computer with the OCR software program so you can
edit the finished documents. I did not see anything that
indicated the Bizhub had OCR software capabilities built into the
unit. Regards, rcampsr
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch
ON while pressing the Utility/Counter key.
3. Touch [Trouble
Reset].
4. Check to make sure that [OK] is displayed and the
it has been reset.
5. After turning off the Main Power
Switch, turn it on again more than 10 seconds after and check if the machine
starts correctly.
Reset your Toners and
Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
