Question about Hobart Welding Tools
I have Hobart Betamig 200 k1.when i swich on the welder ,fan comes up but nothing is happening when pul the triger relay is not comming up no wire fid torch is perfect .Any ideas what could be broken?
6ya staff
SOURCE:
Anonymous
SOURCE: paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
Posted on Nov 04, 2008
luxur4
Ron Jones
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
Anonymous
  • 7 Answers
SOURCE: wiring problem for a hobart G-213 welder
download it for free.
http://www.scribd.com/doc/12408431/1985-Wire-Diagram
Posted on Mar 21, 2009
Anonymous
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
Posted on Aug 20, 2009
Anonymous
SOURCE: Lincoln Pro-mig 175 w/ no wire feed but relay clicks fan runs
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with my MIG 175 Pro is the "voltage selector switch" (part # M15750-1). I took it apart and saw all of the contact points where corroded. I can hold the knob between two settings and the machine will work.
I have the same issue only after about a year of very light use. I am not sure how to prevent this from happening again.
Posted on Sep 04, 2009
My daughter plugged welder into 220 volt outlet. Nothing works: trigger. wire feed motor, cooling fan, gas valve. Bypassed the push button overload-no difference. If I manually depress the magnetic switch...
The weld wiring burning doesn't meant the transformer is good, it only means you have shorted hot to ground and thats what happens when hot touches ground it heats and melts. I would start by looking for a schematic for you welder. Check and making sure your getting good power to the power supply, relay(s) first. Also you can ohm out the transformer and check for the proper resistance but without the schematic/wiring diagram I can't say what the specs are. Normally on these the power comes in to the switch and then to the relay(s) which send power to the fan, and then splits to the trigger which allows power to the transformer, wire feed motor etc. But without the diagram your just shooting in the dark.
Jun 21, 2011 | Hobart Handler 140 Mig Welder
My wire dont feed out some time when i pull the triger
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
Feb 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Instruction book required for welder
I didnt see a betaMig 170 model, but the manuals should be similar for the other betamig manuals. Here is the link:
http://www.hobartwelders.com/service/owners-manuals/
Aug 07, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 140 will not feed wire
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
192 people viewed this question
Top Hobart Welding Tools Experts
David Soto
David Soto
oneStan
oneStan
John Ziehm
John Ziehm
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
